mzhang86 Posted November 22, 2003 Share Posted November 22, 2003 Hi, when I bought my 91 Ls-400 last summer, it was in perfect shape with no extra noise. Now that it's cold in the morning, I let it warm up 5 minutes before I drive. But when i'm driving, I can hear a rattling noise around the area of the front passanger door. Is there a way to locate the rattling noise and stop it? Thanks Quote Link to comment Share on other sites More sharing options...
SW03ES Posted November 22, 2003 Share Posted November 22, 2003 You hear the rattle only when its cold? Quote Link to comment Share on other sites More sharing options...
mejojo Posted November 22, 2003 Share Posted November 22, 2003 If it sounds like it's inside the door, it's easy to remove the door panel and check for loose things. There was a thread a few weeks ago about this topic and 2 people had found the exact same loose nut or bolt. Joe Quote Link to comment Share on other sites More sharing options...
vyhanh Posted November 22, 2003 Share Posted November 22, 2003 Hi, I was one of the 2. It happened to my driver door. I took off the panel and found one of the bolts loose and dropped to the bottom pocket and rattled. VH PS: The other member (I forgot who it was, sorry :() told me that it happened exactly to him (or his friend) Quote Link to comment Share on other sites More sharing options...
mzhang86 Posted November 22, 2003 Author Share Posted November 22, 2003 Hm... I'm unable to find the previouis thread about the door. How would I remove the door panel to check for loose things? Quote Link to comment Share on other sites More sharing options...
vyhanh Posted November 23, 2003 Share Posted November 23, 2003 Since there has been a problem with the server, I am not sure if previous posts could be restored. Anyway, it is much easier to remove the door panel if you have the manual. It is also easier to remove than put it back (easier to have 2 people when putting the main panel back). It is difficult if you don't have the manual since pictures speak a thousand words. It is unfortunate that my scanner is kaput, else I'd post the manual pages for you. Quote Link to comment Share on other sites More sharing options...
hammo400 Posted November 26, 2003 Share Posted November 26, 2003 Hi, I have a '91 Ls400 also, and had the same problem. The cause - so th Lexus guy said - was a fallen-out screw inside the door panel, and some other loose ones. When all were replaced / tightened, the door had the familiar thud, and the problem has, thus far, not returned. I was surprised that they di this for free. I think it was due to the fact that I had asked them to fix this some time ago and the problem returned, so under the 1 year warranty on labor, they were obligated to fix it. This is the one ggod thing about going to the Dealer for service. You have a year's coverage . My rattle sounded like it came from the top of the door, not the middle, and I noticed when I gently banged my elbow behind the door handle inside, that I could hear something loose. It was more prevalent in dry, cool weather ( insulation shrinkage ?). If you're a do-it-yourselfer and have the Service manual, the door panel removal is not hard, but can be tricky. Make sure you reseal the weather strip sheet securely to avoid drafts. Don't OVERTIGHTEN the screws, you may strip them or crack their receptacle, and then your ratlle problems will worsen.. Use locktite or teflon tape on the threads. lock washers are also good. Check all wire harnesses and anything else that may "rattle' are securely clipped / fastened. Use duck tape if you have to, after all, it's INSIDE the door panel ! Good Luck G Quote Link to comment Share on other sites More sharing options...
michaelsn Posted November 26, 2003 Share Posted November 26, 2003 Here's a site that helps you remove the front panel. http://carstereohelp.com/stereoremovalLexu...S400FDrPnlR.htm I was going to convert it to a powerpoint presentation but hesitated when I tried to copy the text and it gave me the "copyright" speech. Good luck! :) Quote Link to comment Share on other sites More sharing options...
hammo400 Posted November 26, 2003 Share Posted November 26, 2003 On http://carstereohelp.com in their "Repair estimate " section, they quote a fix of $190.00 for the BACKLIGHTS of the stereo unit . The stereo unit, presumable uses the same bulbs to backlight as the climate control unit, so , since these guys provide the removal instructions for the stereo / climate control module, you could do the fix for the cost of the bulbs. Worht a try? G Quote Link to comment Share on other sites More sharing options...
michaelsn Posted November 26, 2003 Share Posted November 26, 2003 G, I posted a reply on the thread titled, "Instrument Panel Blackout" We'll discuss the radio lighting issue there and leave this thread for the rattling door panel problem. :) Quote Link to comment Share on other sites More sharing options...
mzhang86 Posted November 27, 2003 Author Share Posted November 27, 2003 Thanks, I'll try to remove it this weekend and look around for loose screws Quote Link to comment Share on other sites More sharing options...
