Spinning Wheels On My Ls400?
LEXDOGG
I am looking to put spinning wheels on my 91 Ls. Has anybody seen these before on a ls400? I dont want them to stick out so it will be a little difficult to find a wheel to accept the spinner. I am going with an 18 inch wheel with a 2 inch lowering spring. what do you guys think??
I found a set called "Dub" bellagio. They are $2499 with tires in 18 inch. They come in 18-26 inches. I am going to call on monday and see if the offset will fit my car. I spent 4 hours searching on the net. These wheels are made for a frontwheel drive, which is what we need. They look like a "davin" wheel. Which means the spinner comes with the rim, not like the spintek which bolts on the old wheel. These wheels look nice. I will let you guys know on monday after i call.
You can actually get the spinners to go over your current rims from what I saw. I'm sure you want to go up to 18" rims though.
Here ya go> http://www.discountedwheelwarehouse.com/Sp...___Spinners.cfm
Here's that Dub spinner LEXDOG is talkin' bout> http://www.discountedwheelwarehouse.com/Du...Dub_Spinner.cfm
These spinpros are priced pretty cheap> http://www.discountedwheelwarehouse.com/Sp...inning_Rims.cfm
