longball425 Posted November 5, 2007 Posted November 5, 2007 I can't find these....where are they located on the engine and how many of them are there? tks
JIBBBY Posted November 6, 2007 Posted November 6, 2007 Two and they are located underneathe your exhaust manifolds on each side of the motor.... You can access from underneathe the car after you remove all the plastic black ground covers... Loosen the bolts, jack the engine up slightly to lift it off the mounts...Replace the mounts lower the engine and tighten the big nuts... Thats it....
longball425 Posted November 6, 2007 Author Posted November 6, 2007 Two and they are located underneathe your exhaust manifolds on each side of the motor.... You can access from underneathe the car after you remove all the plastic black ground covers... Loosen the bolts, jack the engine up slightly to lift it off the mounts...Replace the mounts lower the engine and tighten the big nuts...Thats it.... thanks....I appreciate it
longball425 Posted November 10, 2007 Author Posted November 10, 2007 Two and they are located underneathe your exhaust manifolds on each side of the motor.... You can access from underneathe the car after you remove all the plastic black ground covers... Loosen the bolts, jack the engine up slightly to lift it off the mounts...Replace the mounts lower the engine and tighten the big nuts...Thats it.... thanks....I appreciate it Did you have a different type wrench to access the top nuts?.....I can get a wrench on them but I don't have the room to break the nut free....
longball425 Posted November 10, 2007 Author Posted November 10, 2007 Two and they are located underneathe your exhaust manifolds on each side of the motor.... You can access from underneathe the car after you remove all the plastic black ground covers... Loosen the bolts, jack the engine up slightly to lift it off the mounts...Replace the mounts lower the engine and tighten the big nuts...Thats it.... thanks....I appreciate it Did you have a different type wrench to access the top nuts?.....I can get a wrench on them but I don't have the room to break the nut free.... nevermind...I found an older thread with good info thanks
