TA in KC Posted October 24, 2007 Report Share Posted October 24, 2007 Hello, I have a 1992 LS400 which needs a new power steering pump, and possibly pressure hose. Does anyone know of a good, fairly inexpensive source where I can find a rebuilt pump/pressure hose? Also, are the instructions for changing the pump out best found in the factory service manual, or is there another place online where I might possibly look? Thanks for your help. Thomas Quote Link to comment Share on other sites More sharing options...
ko90ls Posted October 24, 2007 Report Share Posted October 24, 2007 http://catalog.eautopartscatalog.com/autop...part=P%2FS+Pump Here's your link. if you search you should find instructions on removal. I have the directions for a 90 which should be similar. let me know if you wanna check them out. And do a search for the steering rack filter or you will be buying another soon! Quote Link to comment Share on other sites More sharing options...
cardona6569 Posted October 28, 2007 Report Share Posted October 28, 2007 Before you replace the High pressure hose, replace the fitting and gasket not the complete assy. They sell the fitting separate from the whole pressure line assy. Second check the engine valve covers gasket for leaks, couple of mechanics told me my rack was leaking and in all reality it was part the rack and part the valve cover gasket in the passenger side leaking, not the high pressure hose. They dealers know this, but they try to push the high pressure line since it is an expensive Item. The rack will need rebuilding/replacing after a 100,000 miles, I would use synthetic ATF from Mobil it gives much better feeling in the steering system. CPR CPR Quote Link to comment Share on other sites More sharing options...
