The Big Bow Wow Posted September 21, 2007 Share Posted September 21, 2007 hey i just bought a 1990 ls 400 it wont start, i checked its in time, could it be that i dont have the key that has the buttons on it? Quote Link to comment Share on other sites More sharing options...
larryp Posted September 21, 2007 Share Posted September 21, 2007 if the key turns the ignition, then it's not the problem. What happens when you try to start? Does it turn over? Any background on the car's history? We'll need more info to try to help. Quote Link to comment Share on other sites More sharing options...
The Big Bow Wow Posted September 22, 2007 Author Share Posted September 22, 2007 well the only key i have right now is the key that is for making new keys i guess? the car had a blown radiator, i replaced the radiator, checked timing, and checked compression. car wont start though has fuel pressure also i have the parts to change the timing belt and idlers and tensioner, plugs wires caps buttons, waterpump, and all fluids and filters, i just want to see if it will actually run before i dump 500 bucks worth of parts in it to find that it still doesnt work yanno? Quote Link to comment Share on other sites More sharing options...
ko90ls Posted September 23, 2007 Share Posted September 23, 2007 could be your starter? mine just went out. does the car click? also try resetting the Alarm system by locking the doors, waiting until the light has started blinking then unlock the doors. If your Alarm ECU has detected a "break in" it will disable the starter. Quote Link to comment Share on other sites More sharing options...
The Big Bow Wow Posted September 23, 2007 Author Share Posted September 23, 2007 the engine cranks it just wont fire, i called the local lexus dealership, they said without the key with the chip it wont fire up, the key i have is the key for unlocking doors in the event you lock your keys in the car Quote Link to comment Share on other sites More sharing options...
mejojo Posted September 23, 2007 Share Posted September 23, 2007 the engine cranks it just wont fire, i called the local lexus dealership, they said without the key with the chip it wont fire up, the key i have is the key for unlocking doors in the event you lock your keys in the car Such a feature wasn't in a 1990...at least not standard. The key without the button is fine for opening the doors and starting the car...it won't open the trunk is all...it's a valet key. Joe Quote Link to comment Share on other sites More sharing options...
2rotor Posted September 24, 2007 Share Posted September 24, 2007 I would start with easy things like.. Is the fuel pump running? If you spray starting fluid does it try to start..? Cars are pretty easy if you step back and look at what it takes to start the car... fuel, spark, air, and of course compression So all you really need to start is those 4 things.. Figure out which one you are missing.. Quote Link to comment Share on other sites More sharing options...
The Big Bow Wow Posted September 26, 2007 Author Share Posted September 26, 2007 i need a fuel pump. car runs great on ether. anyone know where i can get one cheap? local parts store wants 215 bucks Quote Link to comment Share on other sites More sharing options...
2rotor Posted September 26, 2007 Share Posted September 26, 2007 Before you change the pump, check the relay. Quote Link to comment Share on other sites More sharing options...
mejojo Posted September 26, 2007 Share Posted September 26, 2007 i need a fuel pump. car runs great on ether. anyone know where i can get one cheap? local parts store wants 215 bucks Check the fuel filter. See if you're getting pressure at the filter. See if the filter is clogged. In case you haven't messed with the fuel filter before, it can get very gassy. I recommend having a big bowl and something you can use to plug, or clamp, the hose with in case you have trouble getting the hose back on the filter. (Ask me why I recommend it. Better yet, don't.) If no pressure, check that the pump is getting power...which also involves checking the relay, as recommended. Joe Quote Link to comment Share on other sites More sharing options...
The Big Bow Wow Posted September 29, 2007 Author Share Posted September 29, 2007 the pump is getting power, checked it with my volt meter, i even put 12 volts straight to it but it doesnt do anything, the car sat for a year and a half before i got it im sure its gummed up Quote Link to comment Share on other sites More sharing options...
The Big Bow Wow Posted September 29, 2007 Author Share Posted September 29, 2007 went and got a pump from the local scrap yard, put her in turned the key on and off a few times cranked her over and vroom vrooom shes alive Quote Link to comment Share on other sites More sharing options...
