lexfourcam Posted September 17, 2007 Share Posted September 17, 2007 my 94 ls400 has a steering wheel problem now when i put the key in it doesn't move but when i try to move it using the switch on the side it makes a grinding noise is there ne way to fix this i can't stand driving it with the wheel up so high Quote Link to comment Share on other sites More sharing options...
yidaitianjiaous Posted September 17, 2007 Share Posted September 17, 2007 my 94 ls400 has a steering wheel problem now when i put the key in it doesn't move but when i try to move it using the switch on the side it makes a grinding noise is there ne way to fix this i can't stand driving it with the wheel up so high Try the Auto button on the side and use the up down right left arrow buttons to adjust for best. good luck! Quote Link to comment Share on other sites More sharing options...
dcfish Posted September 17, 2007 Share Posted September 17, 2007 my 94 ls400 has a steering wheel problem now when i put the key in it doesn't move but when i try to move it using the switch on the side it makes a grinding noise is there ne way to fix this i can't stand driving it with the wheel up so high It sounds like the servo motor gears are shot. There is a thread here on that subject. Please use the search function and read alot first. I would do it for you , But this is your forum also. Quote Link to comment Share on other sites More sharing options...
