Front Crankshaft Oil Seal Removal
ko90ls
Hi everyone!
I am in the process of doing a TB/WP replacement and i want to do the crank seal so i need to do this asap. The Quote below is from the article for a 90 LS. First it details the crank shaft seal replacement and says to use the timing belt removal also:
FRONT CRANKSHAFT OIL SEAL
Removal & Installation
Remove timing belt. See TIMING BELT under REMOVAL &
INSTALLATION in this article. Remove crankshaft timing pulley. Cut oil
seal lip and pry seal from oil pump/front cover housing. Apply
multipurpose grease to new seal lip. Use seal installer and tap in new
seal until outer surface is flush with edge of pump case. Reverse
removal procedure to complete installation.
TIMING BELT
Removal
1) Disconnect cable from negative terminal of battery and
wait 20 seconds. Remove air duct and dust covers. Remove battery.
Remove engine splash shield and drain engine coolant. Remove drive
belt, fan, fluid coupling and fan pulley. Disconnect radiator upper
hose from water inlet. Remove radiator and air cleaner. Disconnect air
cleaner hose from intake air connector pipe. Remove air cleaner,
airflow meter and hose assembly.
2) Remove throttle body cover and disconnect cables. Remove
intake air connector pipe. Remove A/C compressor without disconnecting
hoses and move it aside. Remove power steering pump without
disconnecting hoses. Disconnect air hose from air intake chamber.
Remove upper high tension wire cover. Remove right side engine wiring
cover.
3) Remove left side engine wiring cover. Disconnect PCV hose
from valve on left cylinder head. Remove right and left upper timing
belt covers. Remove high tension wiring and clamps from distributor
caps. Remove left side intermediate timing belt cover and ignition
coil.
NOTE: DO NOT pull or bend wiring, otherwise inside conductor may
be damaged.
4) Remove drive belt idler pulley. Disconnect crank position
sensor connector. Remove right side intermediate timing belt cover.
Remove rubber caps from distributor cap. Remove ignition coil. Remove
water by-pass hose and pipe. Remove left side intermediate timing belt
covers. Disconnect crank position sensor wire from clamp on timing
belt cover. Remove rubber caps from distributor cap.
5) Remove distributor caps. Remove distributor rotors. Remove
distributor housings. Disconnect sensor connector from ignition coil
bracket. Disconnect crank position sensor connector from engine wire.
6) Remove alternator. Remove drive belt tensioner located
above alternator. Remove spark plugs. If reusing timing belt, check
installation marks on timing belt. Ensure there are 4 installation
marks on timing belt. See Fig. 13. If installation marks have
disappeared, place new marks on timing belt before removing each part.
7) Position No. 1 cylinder at TDC (compression). Turn
crankshaft pulley and align groove with "0" timing mark on lower
timing belt cover. Ensure timing marks of camshaft timing pulleys and
timing belt rear plates align. If not, turn crankshaft one revolution
(360 degrees). See Fig. 12.
8) Remove timing belt tensioner. If necessary, place new
installation marks on timing belt to match timing marks of camshaft
timing pulleys. When replacing only timing belt tensioner, use a piece
of string to tension timing belt. Place marks on timing belt and right
camshaft timing pulley. Remove tensioner and dust boot. Preset
tensioner before installing.
9) Loosen tension between left and right camshaft timing
pulleys by slightly turning left pulley clockwise. Disconnect timing
belt from camshaft timing pulleys. Remove camshaft timing pulleys.
10) Using puller, remove crankshaft pulley. Remove fan
support bracket. Remove lower timing belt cover, spacer and gasket.
Remove crank angle sensor plate, which also acts as timing belt guide
plate.
11) Ensure installation reference marks are present. Remove
timing belt. Remove lower idler pulley. Using puller, remove
crankshaft timing belt pulley."
first it shows to remove the timing belt which is why i included it. on #10 of the timing belt it says to remove the crank pulley which i have and in #11 is says use a puller to remove the crankshaft timing belt pulley. also on step #1 of the crankshaft seal it says the same thing. do i use the harmonic balance puller? the set of screw that was I have do not look like they will work and there is nowhere to position the center piece? anyone have any expirence with this?
  • 6 years later...
When you replace the seal be sure to look very closely where the seal contacts the crankshaft. If there is a wear line take 1000 grit wet sand paper and clean it up before installing new seal. There is also something called a crankshaft seal saver which is a stainless steel insert that goes over the crank if the wear is really bad. But a quick burnishing on the surface should be all that is needed.
