Hello. I just purchased the Soundgate SDSTOYO Aux Input Interface and I need some help in installing it. It says to connect it to a +12v switched source. Would I find one of these behind the radio when I install it? "Install a 2 amp fuseholder in the red pigtail on the SDSTOYO harness and connect to a +12 Volt switched source." Thank you.
BRYAN
cigarette lighter is a switched source.
I am connecting it so that it is barely seen and looks clean.
Yes I understand, tap into the wiring going to the cigarette lighter....That is what I did on my RX
