qha_vn Posted August 25, 2007 Share Posted August 25, 2007 my CD changer recently failed to play some CDs, sometimes it can play, sometimes it can not when I tried to change from 1 dish to another. sometimes i could not get the cartridge out of the changer. i removed the changer, disassembled it the finally managed to identify and fix the problem. it was becasue of some worn teeth in the mechanism that actually moves the dishes in and out of the CD optical head. I put a plastic strip in between the back of the worn teeth and the steel pole dont really have enough time to write up a tutor, but if someone has the same issue and want to fix by himself, i will try to post some more pix up pic 1 shows where the plastic strip is, i use AB adhesive to position it there pic 2 is after the electric motor is put in pic 3 everthing is in place enjoy Quote Link to comment Share on other sites More sharing options...
RFeldes Posted August 25, 2007 Share Posted August 25, 2007 Well Done!! Quote Link to comment Share on other sites More sharing options...
ono8ono Posted August 25, 2007 Share Posted August 25, 2007 Great Post; I'm sure someday I have to use this fix. :) Quote Link to comment Share on other sites More sharing options...
yidaitianjiaous Posted August 26, 2007 Share Posted August 26, 2007 my cd changer might have the same problem, but it doesn't read cd, err appears on display, any suggestions? my CD changer recently failed to play some CDs, sometimes it can play, sometimes it can not when I tried to change from 1 dish to another. sometimes i could not get the cartridge out of the changer.i removed the changer, disassembled it the finally managed to identify and fix the problem. it was becasue of some worn teeth in the mechanism that actually moves the dishes in and out of the CD optical head. I put a plastic strip in between the back of the worn teeth and the steel pole dont really have enough time to write up a tutor, but if someone has the same issue and want to fix by himself, i will try to post some more pix up pic 1 shows where the plastic strip is, i use AB adhesive to position it there pic 2 is after the electric motor is put in pic 3 everthing is in place enjoy Quote Link to comment Share on other sites More sharing options...
qha_vn Posted August 26, 2007 Author Share Posted August 26, 2007 first thing, mine is 1990 ls400 pioneer cd changer, make sure you have the same or at least similar if you have the same as mine then can you eject the cd cartridge? and when you get err message on the cd player display say on dish 1 can you select dish 2? (you may get same "err" message, but this will ensure you have had the saem problem as mine Quote Link to comment Share on other sites More sharing options...
yidaitianjiaous Posted October 21, 2007 Share Posted October 21, 2007 first thing, mine is 1990 ls400 pioneer cd changer, make sure you have the same or at least similarif you have the same as mine then can you eject the cd cartridge? and when you get err message on the cd player display say on dish 1 can you select dish 2? (you may get same "err" message, but this will ensure you have had the saem problem as mine I think i have the same problems as yours. I took the CD changer out and dismantle everything putside but can't get into inside. if you have more pics to show every step, that wil be highly appreciated. Quote Link to comment Share on other sites More sharing options...
yidaitianjiaous Posted October 23, 2007 Share Posted October 23, 2007 first thing, mine is 1990 ls400 pioneer cd changer, make sure you have the same or at least similarif you have the same as mine then can you eject the cd cartridge? and when you get err message on the cd player display say on dish 1 can you select dish 2? (you may get same "err" message, but this will ensure you have had the saem problem as mine I think i have the same problems as yours. I took the CD changer out and dismantle everything putside but can't get into inside. if you have more pics to show every step, that wil be highly appreciated. I removed and dismantled everything and foud nothing wrong with it. put back on but stull not work. Err displays...eject ok, scan disc from 1 to 6 ok, just don;t play cd but display err. cd magazine easy to malfunction? any suggestions? Quote Link to comment Share on other sites More sharing options...
qha_vn Posted October 23, 2007 Author Share Posted October 23, 2007 in yr case, there would be no issue with the changer machanism since it can still scan the discs. have you cleaned the lense? Quote Link to comment Share on other sites More sharing options...
yidaitianjiaous Posted October 27, 2007 Share Posted October 27, 2007 in yr case, there would be no issue with the changer machanism since it can still scan the discs. have you cleaned the lense? I was trying to clean it with brush cleaning cd, seems cd doesn't run, no rotation....thought maybe cd head problem. can do nothing about it. that;s also why i asked how to clean the cd head in anothr thread... frustrated...thx anyway. at least i tried though proble still there... Quote Link to comment Share on other sites More sharing options...
