What's the firing order for 91 LS..........
look at ur distributor caps, the wires from each plug is labeled on them, if its in a circle then u use the ones in a circle depending if u have it on the left or right bank, the number one piston is labled on the head where each plug is, if u have any doubts as to which is number one then stand on the side of ur car and the head that is furthest forward is number one, if u dont understand any of this then dont work on ur car, have a mechanic do it, also ur plug wires should be labeled as well , DO NOT USE AFTERMARKET PARTS ON THIS CAR!!!! YOU HAVE BEEN WARNED
