Replacing P S Pump
hjcaywood
I Inherited A 1990 LS 400 and it needs a power steering pump. As a student I cant afford to take it to a shop. How do I get to the mounting bolts? What about the hoses? Please help!
If the problem with the PS pump is only leakage, as is typical, you only need an overhaul kit and very few parts from that. There is a fluid pressure control valve that is the usual source of the fluid leak and replacing the seals in that is all that is really needed.
OK, how do I get the alternator out?
WWest- These seals on the PCV are a dealer only part? What are the actual names? thank you.
