hjcaywood Posted July 31, 2007 Share Posted July 31, 2007 I Inherited A 1990 LS 400 and it needs a power steering pump. As a student I cant afford to take it to a shop. How do I get to the mounting bolts? What about the hoses? Please help! Quote Link to comment Share on other sites More sharing options...
larryp Posted July 31, 2007 Share Posted July 31, 2007 Check out the tutorials section of lexls.com. Great stuff. Quote Link to comment Share on other sites More sharing options...
ko90ls Posted August 1, 2007 Share Posted August 1, 2007 most PS pumps are not bad, just expensive. check the steering rack solenoid. do a search and read the longest post you can find. Quote Link to comment Share on other sites More sharing options...
wwest Posted August 2, 2007 Share Posted August 2, 2007 I Inherited A 1990 LS 400 and it needs a power steering pump. As a student I cant afford to take it to a shop. How do I get to the mounting bolts? What about the hoses? Please help! If the problem with the PS pump is only leakage, as is typical, you only need an overhaul kit and very few parts from that. There is a fluid pressure control valve that is the usual source of the fluid leak and replacing the seals in that is all that is really needed. Quote Link to comment Share on other sites More sharing options...
hjcaywood Posted August 3, 2007 Author Share Posted August 3, 2007 I Inherited A 1990 LS 400 and it needs a power steering pump. As a student I cant afford to take it to a shop. How do I get to the mounting bolts? What about the hoses? Please help! If the problem with the PS pump is only leakage, as is typical, you only need an overhaul kit and very few parts from that. There is a fluid pressure control valve that is the usual source of the fluid leak and replacing the seals in that is all that is really needed. Quote Link to comment Share on other sites More sharing options...
hjcaywood Posted August 3, 2007 Author Share Posted August 3, 2007 Thanks for the reply. I have a rebuilt pump but I cant see how to get the old one out let alone the new one in! Any tips? Quote Link to comment Share on other sites More sharing options...
larryp Posted August 3, 2007 Share Posted August 3, 2007 Check out the tutorials section of lexls.com. Great stuff. See earlier post. Should answer your questions. Quote Link to comment Share on other sites More sharing options...
hjcaywood Posted September 4, 2007 Author Share Posted September 4, 2007 I Inherited A 1990 LS 400 and it needs a power steering pump. As a student I cant afford to take it to a shop. How do I get to the mounting bolts? What about the hoses? Please help! If the problem with the PS pump is only leakage, as is typical, you only need an overhaul kit and very few parts from that. There is a fluid pressure control valve that is the usual source of the fluid leak and replacing the seals in that is all that is really needed. OK, how do I get the alternator out? Quote Link to comment Share on other sites More sharing options...
RFeldes Posted September 4, 2007 Share Posted September 4, 2007 Wow..you need a friend with a little mechanical savy. Not very difficult. 3 bolts both ways. Quote Link to comment Share on other sites More sharing options...
jwb007 Posted September 16, 2007 Share Posted September 16, 2007 I Inherited A 1990 LS 400 and it needs a power steering pump. As a student I cant afford to take it to a shop. How do I get to the mounting bolts? What about the hoses? Please help! If the problem with the PS pump is only leakage, as is typical, you only need an overhaul kit and very few parts from that. There is a fluid pressure control valve that is the usual source of the fluid leak and replacing the seals in that is all that is really needed. WWest- These seals on the PCV are a dealer only part? What are the actual names? thank you. Quote Link to comment Share on other sites More sharing options...
