SKperformance Posted July 28, 2007 Posted July 28, 2007 Well i installed my 5 gallon flat black tank , 380 chrome vair compressor ,1/4 inch lines ,water trap and digital display this weekend. Right now i just dropped off the car at a local air suspension shop to build the shocks as i have no expertise in that department. It all fit in the trunk as my gas tank is located between my rear shock and has a large enough opening above it to fit the air tank as i no longer have a sub woofer to block it on the parcel shelf. If you own an LS400 this is the perfect spot to not loose any room. Hopefully i should get the car back by Thursday. I dropped my old oem shocks off at the shop last week to use as templates to save time in making the mounts without having to have the car. but they never did anything until today. I got my car back and it really tucks the back wheels and hides almost half of it when laid out. It will drop even more when i put back my stock wheels for winter.
SKperformance Posted August 1, 2007 Author Posted August 1, 2007 Here are some more. Will try and do a vid this long weekend.
smooth1 Posted August 26, 2007 Posted August 26, 2007 are you gonna add some switches to that bad boy?
