valeman Posted July 24, 2007 Share Posted July 24, 2007 Hi, I noticed that I have a tiny (1mm X 1mm) chip on the hood of the car. My guess is that a tiny gravel or some similar thing has stuck it while on the freeway (I drive it 40 miles on the freeway each weekday) causing the chip. Can anyone offer suggestion on what should be done? Is there an easy DIY fix or some other reasonable option (i.e. I'd like to avoid getting the hood or the entire car repainted)? One option obiously is to leave it alone, but I'd like to know if there's a downside to that and suggestions on ways to fix this. thanks in advance for your suggestions. Quote Link to comment Share on other sites More sharing options...
amf1932 Posted July 25, 2007 Share Posted July 25, 2007 Go to your dealer and buy a touchup pen and put a drop of paint into the chipped area. I had the same thing happen to me......a small chip that I repaired this way.....I don't even notice it anymore. :) Quote Link to comment Share on other sites More sharing options...
CaptainRalph Posted November 18, 2007 Share Posted November 18, 2007 Go to your dealer and buy a touchup pen and put a drop of paint into the chipped area. I had the same thing happen to me......a small chip that I repaired this way.....I don't even notice it anymore. Go to www.5starshine.com They have a great kit for use with the manufacturers touch up paint. Quote Link to comment Share on other sites More sharing options...
geotron Posted September 13, 2008 Share Posted September 13, 2008 i have to say, my es350 white has a pretty weak paint. it gets chip really easily and the paint just peels off like paper (seriously). even my old maxima had better paint than my lexus. Quote Link to comment Share on other sites More sharing options...
mhawkin1 Posted September 13, 2008 Share Posted September 13, 2008 This happened on my starfire 350 - I had the chip touched up and the entire front covered in a clear bra. 6,000 miles later – not another chip. I feel a clear bra is a must with this particular model. Quote Link to comment Share on other sites More sharing options...
kavisic Posted September 14, 2008 Share Posted September 14, 2008 Hi,I noticed that I have a tiny (1mm X 1mm) chip on the hood of the car. My guess is that a tiny gravel or some similar thing has stuck it while on the freeway (I drive it 40 miles on the freeway each weekday) causing the chip. Can anyone offer suggestion on what should be done? Is there an easy DIY fix or some other reasonable option (i.e. I'd like to avoid getting the hood or the entire car repainted)? One option obiously is to leave it alone, but I'd like to know if there's a downside to that and suggestions on ways to fix this. thanks in advance for your suggestions. I had a similar problem. Right after I purchased my ES350 I noticed several little chips. I wondered if there was a problem with the paint job! I used the touch up paint from the dealer and a little "rubbing compound". Then tried not to notice them any more. I don't think anyone else does... Quote Link to comment Share on other sites More sharing options...
amy092380 Posted September 15, 2008 Share Posted September 15, 2008 Go to your dealer and buy a touchup pen and put a drop of paint into the chipped area. I had the same thing happen to me......a small chip that I repaired this way.....I don't even notice it anymore. :) Go to www.5starshime.com They have a great kit for use with the manufacturers touch up paint. I am experiencing the worst paint job ever on my lexus IS250. It's black and I've only had it not even three years. I don't know about you, but I am being more and more persistent on getting answers as to why my paint is worse on this car, than on any other car I've owned. For the price, I think I deserve a car that is goingto hold up under road condidtions, and considering the fact that I barely drive it, and have only 24,000 miles on it, this shouldn't be happening. I have scratches all over the hood, showing white underneath, and spots that were showing in certain areas all over my car that looks like something was eating through the paint. If there was clearcoat on this, nothing would get through to the paint. I am still investigating this and plan to go to Lexus on this issue. I am not wasting my $40,000 to have my car look terrible. What is worse, my fiance drives a hyndai elantra and his is black, he drives it more than me and nothing is on his car. Quote Link to comment Share on other sites More sharing options...
SW03ES Posted September 16, 2008 Share Posted September 16, 2008 As I told you in the other thread, your car needs to be detailed... If you have scratches things are scratching the car...what kind of washing techniques do you use? Do you use an automatic carwash? How often do you polish and wax the paint? And thats not true, clearcoat is no different than color coat...its just clear. Your husband may be more careful how his vehicle is washed... Quote Link to comment Share on other sites More sharing options...
