Hi. I am looking for replacement window trim/molding/weather striping (or whatever its called) for a 98 ES300. I need the piece that partially wraps around both rear door window frames, on the exterior of the vehicle. It starts or small (about a inch wide) at the top of the window and gets much wider (maybe a couple of inches) as it comes down the window frame. Were can I find this piece? Thanks.
Call your local lexus dealer, Ask them who does there body work, Contact that shop and purchase.:cheers: If you want seconds, www.taprecycling.com is the way to go. B)
