Yet Another Power Steering Post......noise, No Leaks
My '93 LS400 has an annoying little problem in hot weather.
After driving it for a while, the steering 'moans' when I turn at stop
or low speed. There's no leak and it functions fine, but it is an
annoying sound.
It's been doing it since I bought the car 2 1/2 years ago and hasn't
gotten any worse. (But no better, either).
I searched the forum under 'steering noise', but didn't find any related
posts. Of course, I may have entered the search words wrong....
Well, maybe your pump is just a little tired. Flush and fill the pump to proper level. Make sure there is no air in the system. With the car running loosen the cap a little while cycling the steering the retighten again. You could also clean the rack solenoid screen. If nothing else works you could buy a new pump or rebuild the old one. www.lexls.com has a tutorial on most of the subjects.
CPR
annoying sound.
You have had the car for 2 years and the pump is new and the noise has not changed?>
You need new fluid. Have you personally changed the fluid or the pump since you owned it?
You may have power steering fluid instead of transmission as it is supposed to have.
