godfather18 Posted June 24, 2007 Share Posted June 24, 2007 Hey guys I replaced the dog bone mount about 8 months ago and need to know how I can tell if I need to replace the other mounts? Quote Link to comment Share on other sites More sharing options...
juno_reaction Posted June 24, 2007 Share Posted June 24, 2007 You can have someone check them. OR usually, when you shift the car into any gear you'll feel the engine or transmission kick. Thats how it felt for me anyway... Quote Link to comment Share on other sites More sharing options...
leert12 Posted June 29, 2007 Share Posted June 29, 2007 If you feel vibration but the shaky kind. Quote Link to comment Share on other sites More sharing options...
mypursuit Posted July 22, 2007 Share Posted July 22, 2007 Hey guys I replaced the dog bone mount about 8 months ago and need to know how I can tell if I need to replace the other mounts? Were you having problems after replacing the front motor mount. If so check the air flow assembly from the air filter to the center of engine. If it has any holes or small rips it should be replaced. Look very closely at the rounded section while (moving it!) around. If you notice tears or rips it maybe letting eccess air into you intake affecting you response. If it has to be replaced it is a toyota parts containing the same number as the lexus part, but cost less money. Call around to toyota dealerships to get the best price. One other thing I tied a plastic bag around the ripped section, make sure it doesn't get burned or caught up on anything. Take your car around the block, you should instantly know the deal. car jerking at start offs, slow speeds and in lower gears almost certainly denotes motor mounts. Quote Link to comment Share on other sites More sharing options...
K2- Posted September 4, 2007 Share Posted September 4, 2007 Hey guys I replaced the dog bone mount about 8 months ago and need to know how I can tell if I need to replace the other mounts? Were you having problems after replacing the front motor mount. If so check the air flow assembly from the air filter to the center of engine. If it has any holes or small rips it should be replaced. Look very closely at the rounded section while (moving it!) around. If you notice tears or rips it maybe letting eccess air into you intake affecting you response. If it has to be replaced it is a toyota parts containing the same number as the lexus part, but cost less money. Call around to toyota dealerships to get the best price. One other thing I tied a plastic bag around the ripped section, make sure it doesn't get burned or caught up on anything. Take your car around the block, you should instantly know the deal. car jerking at start offs, slow speeds and in lower gears almost certainly denotes motor mounts. I just replaced the Dog bone mount and the front canister looking mount but am curious how hard it is to do the rear one(s)? Are there two of them, or just one? Can anyone direct me towards some posts on that, or how any info for me?? Thanks 95 ES300 Quote Link to comment Share on other sites More sharing options...
BUTCH003 Posted September 19, 2007 Share Posted September 19, 2007 Hey guys I replaced the dog bone mount about 8 months ago and need to know how I can tell if I need to replace the other mounts? With the engine running you lift up the hood and have someone hold the brake pedal down and you shift into drive, have them step on the gas. If the engine lifts up significantly chances are your lower motor mounts are bad. Quote Link to comment Share on other sites More sharing options...
Lexlogic Posted September 20, 2007 Share Posted September 20, 2007 Hey guys I replaced the dog bone mount about 8 months ago and need to know how I can tell if I need to replace the other mounts? With the engine running you lift up the hood and have someone hold the brake pedal down and you shift into drive, have them step on the gas. If the engine lifts up significantly chances are your lower motor mounts are bad. Godfather this is the best suggestion from Butch003. Good tip! Lexlogic Quote Link to comment Share on other sites More sharing options...
IlyaIlya Posted September 20, 2007 Share Posted September 20, 2007 ye make sure to stand right in front of car for safety reasons ;) and also put me in will just in case :P Quote Link to comment Share on other sites More sharing options...
goomage Posted September 20, 2007 Share Posted September 20, 2007 Best way is to watch the motor movement when shifting with brake depressed giving it some revs as others have said...thats how the techs do it where i work Quote Link to comment Share on other sites More sharing options...
