bruceb58 Posted June 16, 2007 Posted June 16, 2007 How much transmission fluid needs to be added when draining the transmission pan on a 05 GS300? Also, what sealant is used.? Thanks bruce
dcfish Posted June 17, 2007 Posted June 17, 2007 Just pull the drain plug, You don't have to drop the pan. 2 qts. t4 atf. Drain and fill just like an oil change.
