wandawoods Posted August 31, 2003 Posted August 31, 2003 can anynone tell me whether my 96 SC400 has an interference engine or not? just bought it on eBay with 166K, but I am not sure the timing belt was replaced or not. I heard that a broken timing belt on non-interference motor would just quit running, no real harm is done! also, what is the factory recommended mileage to replace TB? thanks in advance for your time.
SPORTcoupe300 Posted August 31, 2003 Posted August 31, 2003 As far as I know the SC400 engine is a non-interference engine, but don't take my word for it. Factory reccomends 90K and I agree. If in doubt, just do it anyways.
JPI Posted September 2, 2003 Posted September 2, 2003 It's a non-interference motor. Only on VTT-i engine. I see timing belt last up to 140k miles. Just to be safe I would replace it now. JP IMPORTZ
wandawoods Posted September 2, 2003 Author Posted September 2, 2003 It's a non-interference motor. Only on VTT-i engine. I see timing belt last up to 140k miles. Just to be safe I would replace it now. JP IMPORTZ Hi JPI, thanks for the info. for a 166K, I can image it had TB replaced at least once, but to be safe I will go ahead to replace TB. at least I know now it's a non-interference, TB replacement should not be as expensive as timing chain on Mercedes 420SEL which costed me $1200, parts+labor! assuming it is not to be serviced by dealer, how much can I expect to pay TB replacement at a 'regular' shop? I also own a 94 LS400 (w/115K miles) with the same 1UZ-FE engine. I assume it's also a non-interference? thanks again for your time!
teke52 Posted September 2, 2003 Posted September 2, 2003 I was quoted $1075...ouch! But that's in NJ...the Toy Shop...they specialize in Toyota and Lexus repairs. That's for belt, pump, tensioner, idler...the works.
WannaBagDaSC Posted September 3, 2003 Posted September 3, 2003 hey teke where in NJ are you from and where is this shop you speak of?
SC93 Posted November 8, 2011 Posted November 8, 2011 I have been trying to get a straight and correct answer on this topic, off and on, for freakin years!! It seems like I continually encountered self-professed experts around every corner who continually contradicted each other. Frustrating!! I finally got my hands on an authentic Lexus dealership shop repair manual and began combing the pages. I finally found this statement on page EM-4 (Engine Mechanical-4), word for word, from the actual creator of my 1993 1UZFE. "Pistons are made of high temperature-resistant aluminum alloy, and a depression is built into the piston head to prevent interference with valves". BAMMMM!! :) At least I know I'm in the clear with my '93 SC.
Evans92 Posted October 25, 2012 Posted October 25, 2012 The Factory Service manual for 1992 SC400 has the same statement : "Pistons are made of high temperature-resistant aluminum alloy, and a depression is built into the piston head to prevent interference with valves" Page EM-4
Murco Posted October 29, 2012 Posted October 29, 2012 The 1992-1996 engines were "non-interference" engines. In 1997 higher compression pistons and lighter rods raised the horsepower to 260 and those, as well as the 1998-00 VVTi engines, were interferance engines. If you have basic metric tools and some mechanical background the belt is actually quite easy to swap.
