Air Bag
Several times, I have disconnected the battery for some work, and the air bag light came on. And stayed on.
Lexls is a contributor who has a great procedure for fixing this condition. Check out the search portion of this site.
Just be sure that you don't have a real problem with the air bag.
thanks for your replys, just to be safe i will take it to the dealer to make sure its not a problem with the air bag, my inspection expires this month, is that light on a cause for failure, i'll check lexls.com for the procedure also thanks
If the light went off, you should be just fine. There should be no problem with the Air Bag. I went through this same problem with a Honda Accord, too. Turned out it was the same computer glitch. Don't waste good money going to the dealer.
Best of luck.
