predator Posted May 28, 2007 Share Posted May 28, 2007 I'm getting a bit of vibration through the wheel, even at idle. I've got under the car and checked the rear transmission mount. It doesn't seem cracked, or obviously perished, however I did notice the rubber tended to "bow" out at the sides when I felt it with my fingers. Does this mean it's on it's way out? or should I be look at the front mounts? I've attached a very rough picture of what it looks like.. may not be entirely accurate in terms of how it sits - but might give you an idea of what I can see. The red shows how the rubber sort of bows out. Quote Link to comment Share on other sites More sharing options...
dcfish Posted May 28, 2007 Share Posted May 28, 2007 I'm getting a bit of vibration through the wheel, even at idle. I've got under the car and checked the rear transmission mount. It doesn't seem cracked, or obviously perished, however I did notice the rubber tended to "bow" out at the sides when I felt it with my fingers. Does this mean it's on it's way out? or should I be look at the front mounts? I've attached a very rough picture of what it looks like.. may not be entirely accurate in terms of how it sits - but might give you an idea of what I can see. The red shows how the rubber sort of bows out. Change the motor and transmission mounts. It is in expensive and fairly easy job. Quote Link to comment Share on other sites More sharing options...
