Fog lights for 92 SC400
Earl
  • 2 months later...
Not exactly sure what you're trying to say. Is it the parking lights or the hazards? The Fog lights on the 95 SC300/400 use a H3 bulb, and isn't long enough to move all the way down to the lower part of the car. You might want to check out a body kit from somewhere. There are a few options available for the SC300-400's when it comes to body kits. Try them out.
  • 2 months later...
Ok let me tell you this bit. The corning lights you are talking about are very usefull, actually instead of haveing them turn on only when the appropriate blinker is activated i have both of my corning lights turn on and act as 2 fog lights working at the same time when i use my city lights. I did this by purchasing 15 dollars worth of a relay and fuses from radio shack. The website i used issc300/400 faq and is a very good step by step that is dummy proof. Plus if you need hep just e-mail me and i have some tips watts@narrowgate.net.
Lexsc400
I just picked up a set of 96 fog lights from the local junk yard and am going to try fitting them into the pre 95 bumper opening for the cornering lights. The units look very similar but I have not taken anything apart yet on my car so Im not sure if they will fit or how much modification is involved.
If the weather is nice I should know something by sunday.
if they are from the same generation they should fit.
i'm pretty sure the 92-96 SC's all use the same type of foglights. i could be wrong, but if they look similar, it should work fine.
