Does anyone know where i can download a manual for the nav system i just purchased an 04 and it did not bring the navigation manual. its a touch screen. Even if anyone knows where i can get the actual manual that would be great to. Thanks.
I have the 05 ES330 NAv Manual in PDF. Send me a PM with your email address and I'll send it over
andrew
andrew
Thanks Andrew i actually was able to call Lexus and they are sending it to me at no cost. Im still waiting on it if they take to long i will definatley take you up on that offer. Thanks :cheers:
  • 8 months later...
andrew
Andrew,
I am new subscriber to the Forum as I just purchased a 05 ES330. It came without a manual for the navigation system and I am finding it difficult to learn. Any chance I could get you to send me a copy of the PDF you have?
Many thanks,
Darrel
Does anyone know how to activate the turn-by-turn guidance in a 2004 ES330? My friend says that when you starts the navigation guidance, the route he is supposed to travel shows up red, but there is no voice guidance. Only at the end of the journey does it say anything (you have reached your destination).
Is there a settings menu or a volume menu he should go to?
  • 3 months later...
Also looking for a copy of that manual in PDF: bdmurray AT google's mail service
Thanks in advance.
UPDATE: For those looking for this manual, or any other manual, just register as an owner on Lexus.com, all the manuals are on there in PDF form.
  • 4 months later...
andrew
Hi Andrew,
I have an IS300 and now I'm thinking to get an ES. I'm choosing between a 2007 ES350 or 2006 ES330. Can you send me the pdf file for ES330 navigation manual? I want to compare navigation systems before I make my decision because I use it a lot. My email is stantwk@hotmail.com. Thank you very much
The systems are almost exactly the same. The 07's has a higher resolution screen and a little bit different interface layout.
One big change is that on the '06 there is a hack that allows you to input navigation destinations when driving, on the '07 that hack doesn't work. If you upgrade the navigation DVD on the '06 though it also removes the hack.
Thanks for your information.
So if I update the 06 ES with a 07 DVD I can input the destination when driving too?
No, if you update the system with an 07 or 08 disc it will do away with the workaround that allows you to input destinations when driving.
Its not a big deal though, just enter the destinations before you leave. I use mine a lot too (my system has no workaround) and it doesn't bug me.
  • 10 months later...
I need one, too. Did you ever get a reply??
  • 6 years later...
I was able to replace successfully the factory stock Pioneer system on my 2004 Lexus ES330 with aftermarket head unit (GPS, DVD, Radio, etc.) all for less than $250. Here is my installation video for others who may be interested.
