i think this topic has been mentioned way back but i try using the search button option but for some reason it just ends up showing the most recent posts :o anyways, i open that cover thats inside the center console and i dont seem to notice anything stuck. i hope nothing is broken since its costly to replace anything for a lexus (unless u get lucky in ebay :D )
sorry i am lost on what you are saying
do you press the cupholder bar of wood and the CH does not automatically come out unless you pull it out
or it just wont come out even if you pull on it
i would sayt eh tracks arre full of coke orsome sugar base that is gumming up it
claen em and should be ok after
yep... thats the case... ill try cleaning it using armor-all wipes or something. would u recommend using wd40 though?
i wouldn't use wd40 as it might damge the wood finish below
a good cleaner like windex or spray clean form most dealers or spray nine on a q tip run along the rails should help alot
then use some white grease or siicone spray on the track
