Spark Plug Gs300
you won't notice a difference except the change interval-60,000 for platinum and 100,000 for the iridium cost effective the platinum works out better and is the proper plug for the car. :D :D :D :cheers:
  • 1 year later...
this post indicates that the platinum plugs are the proper plug for the gs3. mine is a '98. i had planned to use the ngk iridium. they seem to be hard to find. does anyone have a part number?
should i go iridium ngk or platinum?
i went ahead and ordered the standard irdium ngk's
the chart you attached above is for a '93. i have a '98. are those plugs what you recommend for the '98?
Yes, the IFR6T-11 should work just fine, or the BKR5EIX B) Make sure you compare them to your old ones and let us know how they work out.
