Thi Posted August 24, 2003 Share Posted August 24, 2003 I just drain and fill the transmission fluild on my LX 450. The service manual states that it takes 2.1 qts when drain and refill. I put in 2.5 qts, but it's way below the cold level. I drove it and rechecked, but it's at or little below the cold level when the fluid is hot. I put in the rest of the 3rd qt and it's still not at the full level. Does anyone experience the same symptom? Thi Quote Link to comment Share on other sites More sharing options...
ellieoh Posted August 25, 2003 Share Posted August 25, 2003 I think the transmission fluid has to be checked with the engine running and in neutral, check your manual for the correct procedure. The trans fliud volume is important but the level on the dipstick is the recommended way to determine the fluid level. Regards David Quote Link to comment Share on other sites More sharing options...
Thi Posted August 25, 2003 Author Share Posted August 25, 2003 I checked the fluild level when the engine is running and the transmission is in neutral and park positions. Quote Link to comment Share on other sites More sharing options...
tem Posted August 26, 2003 Share Posted August 26, 2003 My Dump and Refill took 4 quarts. The amount that drains out is effected by the amount that drains back from the Valve Body, Clutches, Servos, and converter. Quote Link to comment Share on other sites More sharing options...
Thi Posted August 26, 2003 Author Share Posted August 26, 2003 Thanks for the info. The thing that concerns me is that the service manual and user manual specify 2.1 qts for "drain and refill". Could it be the info in the manual is incorrect? I also check in the Alldata system. By the way, I use Mobil 1 synthetic transmission oil. Quote Link to comment Share on other sites More sharing options...
Rookie Posted December 13, 2003 Share Posted December 13, 2003 I'm getting ready to change mine out at the next oil change, and also notice the discrepancy in the repair manual.. odd. Thi- any reasons for upgrading to the synthetic? Manual calls for Dexron II or III. Also, anyone aware of any difference between the Valvoline, Pensoil or Proline Dexron III products? Thanks, Rookie Quote Link to comment Share on other sites More sharing options...
Thi Posted December 13, 2003 Author Share Posted December 13, 2003 Rookie, With synthetic oil, I thought that it would have better viscosity to withstand the extreme temperature hot/cold. In addition, I don't have to change the oil as often. Just saw a show on TV about the Ferrari Munzo (spell?), it uses a special formulated Shell oil that costs $60/quart .... ouch. The oil change would cost around $700. They said that the manufacturer will void the warranty if not using the particular oil. Well, the car costs $600,000+ and can go from 0-60 in 3+ seconds. Thi Quote Link to comment Share on other sites More sharing options...
doiturself Posted December 13, 2003 Share Posted December 13, 2003 Thi, Since you replaced the new oil with synthetic, I suggest you to do flush instead than just drain the old one out, it's not good to have a mixed in there. To get the job done right, you need to have a machine that can do a flushing job. The reason that you are not sure, how much oil need to be filled up because you didn't get all the old one out from a draining. One more thing to keep in mind, if you have more transfuild that it should be, you will damage your transmittion in the future another word is called "flood" How to know your transmittion oil is new after replacing new one, the fluid should be "pink" as virgin. After 1000 miles drive should still be PINK.... I REALLY MEANT PINK!!!! Quote Link to comment Share on other sites More sharing options...
