Hi ,
What is the best value in replacement rotors (F/R) and semi-metallic pads (F/R) for my 1998 LS400.
Many online parts stores have good prices. I WANT TO STAY AWAY FROM AN $1200 JOB AT THE DEALER WITH THEIR CRAPPY PARTS AND OVERPRICED SERVICE.
Which are the best for pads ? EBC? Raybestos?
Rotors? Mountain? Centric? EBC?
Suggestions are MOST welcome
Thank you
Hammo400
98White LS 400
I used pads from the dealer (after I embarrassed them into almost matching parkplacelexus.com's price) and Brembo rotors from TireRack for $68 each. So far very happy with the results. Did the job in my driveway in about an hour for the fronts.
Bob
Hi ,
Thank you
Hammo400
98White LS 400
I used NAPA Ceramix Pads: Front, CMX7544
Rear, CMX7491 on my '99 LS. I haven't needed to replace rotors yet.
Bob
Hi ,
Thank you
Hammo400
98White LS 400
I bought mine from irontoad.com. Factory pads came from a Lexus dealer in Pennsylvania. I think $63 for the front and very easy to install. You can actually put these pads on using the tools the car carries on board. The hardest part is getting the wheel lugs loose.
Try calling Crystal Lake Pit Stop 815-455-1300 They have F&R rotors that are as good as OEM and pads to match very good prices. I have them on my 98 LS with NO problems after 35000...
If you don't want to have any problems, don't even think about semi-metallic pads. Lexus or toyota rotors are soft and only ceramic pads would work like they suppose to. I got Brembo rotors and pads from Tire Rack....don't forget about anti-squil shims when changing pads.
Since brakes last so long anyway, I always use the brake pads made by the manufacturer. I have tried many aftermarket pads before and none were great and some were terrible.
