I recently bought a LS 400 Black. I am trying to keep it looking new. I washed it, cleaned the paint, polished it and waxed it. I bought a car cover from Autochic. I put it on and it rained (they told me it was OK in the rain). The next morning there was some marks all over the paint and windows. I have tried clay and paint cleaner and scratch remover. Nothing has taken them off. Does anybody have any ideas? I am now thinkg about suing the company for a new paint job. Thank you.
i am not sire why it would scratch it
i have a cover and i used it or years
it is a blue one that is breathable made of some 3m material
i have found the car has to be clean before using the cover
or it will scratch the finish
as the cover rubs the dirt against the paint
also remeber to always use the same side down
as this keeps one side more dirty than the other
can you explain more on what the scratches are like?
I will take a picture tomorrow (It is dark now) and let you see. They look like really bad water spots but are white. Thanks for the reply.
My bet is the waterproofing agent in the cover bled through staining the paint. What kind of paint cleaner have you tried to use?
How much was the cover, what type of material is it etc?
I used Meguires.
The cover was $130.00. Here is the blurb from the website- "ALL-WEATHER – Three layer lightweight protection for severe weather conditions.
Lightweight and breathable, yet extremely durable.
Polyester construction with UV protected outer shell to resist sunlight and moisture.
Smooth inner shell resists dirt and is easy on paintwork.
Quick drying … will not rot or mildew.
Custom and standard sizes available.
Machine washable … fits most home washers. "
Whats the exact name of the cleaner. Its possible something stronger might take it out.
The deep crystal paint cleaner? That is probably just not strong enough.
Try and get your hands on something like Meguars Mirror Glaze Swirl Remover 2.0 #9, or Meguiars ScratchX and see what that removes. Those products are abrasive and they'll have a better shot at removing the staining.
I did try the scratchX already but I will try again. I think you were right about the cover. I felt the underside and it had what appeared to be a white film.
I really think it is the cover because the marks are also on the windows and sunroof. They are very hard to get off the glass as well.
ahhh
now i know what it is
basically the car was dirty
then it rained
with it on the car
the newmaterial bled and mixed witht he dirt
then the sun baked it on
this is my guess
but it should come off pretty easy
i had that problem too when covering my car the first couple of times
once you said the windows
i rememberd the pain in the !Removed! it was to remove it sometimes
i think you'll be able to get them off. Have you tried a bug and tar remover? Try something along those lines as well.
SW03ES toke the words right out of my mouth!bug and tar remover should solve that problem.
