wbrian63 Posted January 30, 2007 Share Posted January 30, 2007 2002 GS 430 - Mark Levinson system. Subwoofer blown (PO damage). Rear package shelf has to come out to R&R unit. Looks like rear seat has to come out first - no clue as to where to start. Any ideas? Quote Link to comment Share on other sites More sharing options...
Jimmy Yang Posted March 7, 2007 Share Posted March 7, 2007 I'm new at this too but I saw some direction from this one website and it says that all you have to do is pop out the cover of the sub and then remove the subwoofer. Here's the link http://www.carstereohelp.com/stereoremovalLexusSC400RSpk.htm Hope this helps ;) Quote Link to comment Share on other sites More sharing options...
1sikgs Posted March 8, 2007 Share Posted March 8, 2007 this has been covered before. but to help out, you have to remove the seat first. just pull the seat bottom up to release it from the clips. it's a little hard but pull and it will come out. next there are a few bolts and the bottom and at the top. the bottom bolts are easy to see. the others are behind the head rest. remove the head rest and there is a flap. the bolts are behind those flaps. next remove the pillar covers. they are just held in with clips. then the rear deck cover comes off. there is a black mat covering the bolts holding the sob in. once you remove the mat, just take out the bolts and replace the sub. reverse the process to reinstall Quote Link to comment Share on other sites More sharing options...
