I recently had new struts all round. I noticed that Monroe has the same part numbers for the 97-01 Camry as it does for the 97-01 ES300.
Is this because the struts are the same, or is it because Monroe reckons that a physical fit is all that's needed?
i wouldnt think so but its possiable.i know the ride is no were near the same between the camrey and the es so thats why i think there different but not to sure about 97 to 01 year.
the mcv 20 chasiss is the same camry and es 300 ont the v6 platform
97-01
they fit perfectly no difference
at all
the struts are designed differently for each car for hanling dynamics though
hi, there. mcv. skperformance thought you might know how to get to the foglights in 2000 es300. please advise. i think i understand how to remove arch liner, then it's all mystery thereafter.
thanks.
actually there is a screw holding the back of the fog light housing...
if u want to change out the blub u need to unscrew it >> take out the whole housing ...then the next step is pretty easy...>> change the blub...
make sure u do it on a sunny/ bright day.. or u wont see anything inside..
my advise is do it on some slope and face the car upward u can see it more clearly..
the model of the light blub is: H3
thanks for the quick reply. actually, the lens is a little rough around the edge and i wanted to polish it. is the procedure different for taking out the whole housing?
i am almost impressed with this posting. i actually sound like i know what i am talking about, which i don't.
