Abs Wheel Sensor
gp1200x
My wheel sensor for the drivers front (AWD) has to be replaced. Part number is 89543-48010
The cheapest price I have found is $181 +. Does anyone know if I can use a Camry part or Highlander part for replacement? This has to be a common part used in some of the other vehicles. Anyone have a spare they want to sell. I may check the local scrap yards......This same part on my Mercury and Ford is $29!!
If it is the same hall type magnetic pick up sensor then it is a press in type. When the abs system throws a code it is usually because the wheel hub is worn throwing a code to the abs . When it does it usually means both have to be changed as you cannot reuse the old sensor.
My problem is the circuit inside the pickup is open (winding open), so no pluse can be picked up. The axle and hub are fine. I'm trying to find one that matches the Rx size since the magnetic pickup has to be within a fairly tight distance spec from the teeth on the axle.
