rockne Posted December 7, 2006 Share Posted December 7, 2006 My low tire pressure warning keeps coming on everytime I get in the car when the temp is below 30. It goes off after about 5-10 minutes of driving. I know that when your tires heat up the tire pressure rises but I sure hope this doesn't happen the entire winter, it's very annoying. Anyone else have this problem? Quote Link to comment Share on other sites More sharing options...
terry993 Posted December 8, 2006 Share Posted December 8, 2006 I don't have my manual handy, but maybe you could have the dealer adjust or disable it in the personal preferences. Annoying, and why I declined this option. Quote Link to comment Share on other sites More sharing options...
bartkat Posted December 8, 2006 Share Posted December 8, 2006 I think it's +- 4 or 5 PSI change before the TPMS alarms. Tires will lose about 1 PSI for every 10 degree F drop in ambient temperature. If you aired your tires in 70 degree weather then it's possible the alarm would go off at 30 degrees, especially if they were a little on the low side to begin with. Best thing to do is check your cold inflation pressure when the weather turns cold. If you're checking them on a regular basis, then you ought to catch that anyway. Quote Link to comment Share on other sites More sharing options...
lexus411 Posted December 8, 2006 Share Posted December 8, 2006 get nitrogen put in your tire. Alot less sensitive and less air seepage. Quote Link to comment Share on other sites More sharing options...
rockne Posted December 8, 2006 Author Share Posted December 8, 2006 It happened again tonight, although it is 28 degrees down here in Macon GA tonight. I'm getting tired of that exclimation point lit up in my face while I'm driving though. I'm surprised other people aren't having this problem. Quote Link to comment Share on other sites More sharing options...
bartkat Posted December 8, 2006 Share Posted December 8, 2006 It happened again tonight, although it is 28 degrees down here in Macon GA tonight. I'm getting tired of that exclimation point lit up in my face while I'm driving though. I'm surprised other people aren't having this problem. Did you check your actual tire pressures? Quote Link to comment Share on other sites More sharing options...
rockne Posted December 12, 2006 Author Share Posted December 12, 2006 It seems low, it's 31 on all four corners. What's the recommended tire pressure? Quote Link to comment Share on other sites More sharing options...
bartkat Posted December 12, 2006 Share Posted December 12, 2006 It seems low, it's 31 on all four corners. What's the recommended tire pressure? 35 front and 37 rear. Quote Link to comment Share on other sites More sharing options...
lesterah Posted December 30, 2006 Share Posted December 30, 2006 For those of you that are having the tire pressure warning, when the weather gets cold to where the warning is going off, initialize the system again for the cold temp, the owners manual has the procedure for doing the reset.. I believe the warning comes on at approximately 3 psi from the initial setting... Or as one said have the air replaced with nitrogen, pressure remains the same cold or hot... Costco putts it in tires they install tires. George Quote Link to comment Share on other sites More sharing options...
bartkat Posted December 30, 2006 Share Posted December 30, 2006 For those of you that are having the tire pressure warning, when the weather gets cold to where the warning is going off, initialize the system again for the cold temp, the owners manual has the procedure for doing the reset.. I believe the warning comes on at approximately 3 psi from the initial setting... Or as one said have the air replaced with nitrogen, pressure remains the same cold or hot... Costco putts it in tires they install tires. George When tire pressures drop due to cold weather, you sould pump them back up to spec. Quote Link to comment Share on other sites More sharing options...
BigMush818 Posted December 31, 2006 Share Posted December 31, 2006 move to SoCal Quote Link to comment Share on other sites More sharing options...
Cherokee_Outlaw Posted January 1, 2007 Share Posted January 1, 2007 For those of you that are having the tire pressure warning, when the weather gets cold to where the warning is going off, initialize the system again for the cold temp, the owners manual has the procedure for doing the reset.. I believe the warning comes on at approximately 3 psi from the initial setting... Or as one said have the air replaced with nitrogen, pressure remains the same cold or hot... Costco putts it in tires they install tires. George When tire pressures drop due to cold weather, you sould pump them back up to spec. Yes... I thought it was the cold weather... but I did check the PSI... 1 was below 30.... so never just assume its the cold... Also.. Thats the only time its gone off... granted... its been fairly nice up her in New England.. but it has gotten into the low 20s a few times.... Quote Link to comment Share on other sites More sharing options...
