rhsmd Posted December 2, 2006 Share Posted December 2, 2006 the lexus brochure states that the top speed for the is 350 is 140 mph,which is electronically limited. the speedo shows 160 mph. is there an over ride? Quote Link to comment Share on other sites More sharing options...
dcfish Posted December 2, 2006 Share Posted December 2, 2006 the lexus brochure states that the top speed for the is 350 is 140 mph,which is electronically limited. the speedo shows 160 mph. is there an over ride? If I may ask, Where do you plan on going 160 much less 140 ? :whistles: Quote Link to comment Share on other sites More sharing options...
bartkat Posted December 2, 2006 Share Posted December 2, 2006 Back in the day most speedometers had a top number of 120, but most cars wouldn't do it. That 160 is just a number. Quote Link to comment Share on other sites More sharing options...
rhsmd Posted December 2, 2006 Author Share Posted December 2, 2006 the lexus brochure states that the top speed for the is 350 is 140 mph,which is electronically limited. the speedo shows 160 mph. is there an over ride? If I may ask, Where do you plan on going 160 much less 140 ? :whistles: there used to be a tme when speedometers never went above 85(early 1980's). the marked speed limit in my area is 70mph, yet we are buying cars with 306 hp. i don't know where i'll go 140,( although there are places out here in the wild west where you can), i just want the capability. Quote Link to comment Share on other sites More sharing options...
dcfish Posted December 2, 2006 Share Posted December 2, 2006 the lexus brochure states that the top speed for the is 350 is 140 mph,which is electronically limited. the speedo shows 160 mph. is there an over ride? If I may ask, Where do you plan on going 160 much less 140 ?:whistles: there used to be a tme when speedometers never went above 85(early 1980's). the marked speed limit in my area is 70mph, yet we are buying cars with 306 hp. i don't know where i'll go 140,( although there are places out here in the wild west where you can), i just want the capability. Is it knowing that the car is capable of max speed and not being restricted by the mfg. ? Quote Link to comment Share on other sites More sharing options...
Rx330driver Posted December 2, 2006 Share Posted December 2, 2006 lol my RX shows 140 but i doubt it will bet past 120. its limited at 110 though or else the tires will burst. i think it involves changing something in the ECU. its entirely possible but what will be the difference. Quote Link to comment Share on other sites More sharing options...
rhsmd Posted December 2, 2006 Author Share Posted December 2, 2006 the lexus brochure states that the top speed for the is 350 is 140 mph,which is electronically limited. the speedo shows 160 mph. is there an over ride? If I may ask, Where do you plan on going 160 much less 140 ?:whistles: there used to be a tme when speedometers never went above 85(early 1980's). the marked speed limit in my area is 70mph, yet we are buying cars with 306 hp. i don't know where i'll go 140,( although there are places out here in the wild west where you can), i just want the capability. Is it knowing that the car is capable of max speed and not being restricted by the mfg. ? it's probably my own psychiatrical(sp) querk. i don't like restriction on my personal possesions. Quote Link to comment Share on other sites More sharing options...
dcfish Posted December 2, 2006 Share Posted December 2, 2006 the lexus brochure states that the top speed for the is 350 is 140 mph,which is electronically limited. the speedo shows 160 mph. is there an over ride? If I may ask, Where do you plan on going 160 much less 140 ?:whistles: there used to be a tme when speedometers never went above 85(early 1980's). the marked speed limit in my area is 70mph, yet we are buying cars with 306 hp. i don't know where i'll go 140,( although there are places out here in the wild west where you can), i just want the capability. Is it knowing that the car is capable of max speed and not being restricted by the mfg. ? it's probably my own psychiatrical(sp) querk. i don't like restriction on my personal possesions. I'm very much the same way, There is a "Black Box" thread in the recent posts and I won't even go there. What's mine is mine ;) Here it is : http://us.lexusownersclub.com/forums/index...c=33687&hl= Quote Link to comment Share on other sites More sharing options...
1QuickIS Posted December 3, 2006 Share Posted December 3, 2006 Coming home from Reno NV, I hit 146-7ish so I don't know what the actual limiter is set at, but I can tell you that it is a governer cause the car still had more ummph left. I was at like 4.5k on the tach. The good news is that the car felt pretty stable at that speed. Unlike my old Stang GT that felt like it was flying thru the air, very light in the front end, this car felt hunkered down. Quote Link to comment Share on other sites More sharing options...
bartkat Posted December 3, 2006 Share Posted December 3, 2006 The new IS is amazingly comfy at those high speeds. You reallly don't feel like you're going so fast till you start catching up with traffic or whatever and need to slow down. :D Quote Link to comment Share on other sites More sharing options...
larry chester Posted December 4, 2006 Share Posted December 4, 2006 The new IS is amazingly comfy at those high speeds. You reallly don't feel like you're going so fast till you start catching up with traffic or whatever and need to slow down. :D . . . . . . . . . . . or until you look in the rear view mirror and see the guy with the light bar on the top of his car catching up with you!!! LOL :whistles: To misquote Jim Croche from Speedball Tucker, "146 was the route you were on, it was not the speed limit sign." :) larry Quote Link to comment Share on other sites More sharing options...
dcfish Posted December 4, 2006 Share Posted December 4, 2006 The new IS is amazingly comfy at those high speeds. You reallly don't feel like you're going so fast till you start catching up with traffic or whatever and need to slow down. :D . . . . . . . . . . . or until you look in the rear view mirror and see the guy with the light bar on the top of his car catching up with you!!! LOL :whistles: To misquote Jim Croche from Speedball Tucker, "146 was the route you were on, it was not the speed limit sign." :) larry Quote Link to comment Share on other sites More sharing options...
lesterah Posted January 1, 2007 Share Posted January 1, 2007 the lexus brochure states that the top speed for the is 350 is 140 mph,which is electronically limited. the speedo shows 160 mph. is there an over ride? If I may ask, Where do you plan on going 160 much less 140 ?:whistles: there used to be a tme when speedometers never went above 85(early 1980's). the marked speed limit in my area is 70mph, yet we are buying cars with 306 hp. i don't know where i'll go 140,( although there are places out here in the wild west where you can), i just want the capability. Is it knowing that the car is capable of max speed and not being restricted by the mfg. ? it's probably my own psychiatrical(sp) querk. i don't like restriction on my personal possesions. The limint is for engine rpm, thus the speed, I doubt if they care how fast you go the care to warranty an engine thus they don't want you to blow it up.. haha George Quote Link to comment Share on other sites More sharing options...
