Engine Light
donald3
Did you check your dipstick to make sure the oil level is correct. The 4.0 engine uses 5 and 2/3 qts of oil. If the level is low or high that might cause it to come on. I agree that it is not normal for it to come on after an oil change
I have to agree that's it's probably just a coincidence. This goes against my grain because I don't believ in them. You may have to go get a code check to see what is going on. I'll try to look up some info and post it later. Going to the junkyard in a little while
