meddle Posted August 11, 2003 Posted August 11, 2003 http://www.tmengineering.net/suspension/br...en/make/sc.html Im going to buy the eibach lowering springs with the tokico shocks. Ive heard that it would be best to replace the control arms on my high mileage car while im at it. Im a little confused about which of those components I will need though......
Bubbles Posted August 11, 2003 Posted August 11, 2003 It's the Polyurethane Control Arm Bushings. I think front is more important than back because stiffer control arm in front gives less deflection in steering. I emailed Daizen a while back and they said they give you all the instructions. I'm not sure what tools you'll need.
SPORTcoupe300 Posted August 11, 2003 Posted August 11, 2003 I see what you mean. On the Daizen website it gives the following part numbers for the actual cntrol arms: Front - P/N S1-2002 Rear - P/N S1-2003 Those numbers match the ones on TM website's listing of bushings. I guess you need to get a hold of TMEngineering to find out what the deal is.
meddle Posted August 11, 2003 Author Posted August 11, 2003 It's the Polyurethane Control Arm Bushings. I think front is more important than back because stiffer control arm in front gives less deflection in steering. I emailed Daizen a while back and they said they give you all the instructions. I'm not sure what tools you'll need. Im sorry for my ignorance, but are the bushings just a part of the control arm? Id get under my car and try to figure it out, but its raining.
AWJ Posted August 11, 2003 Posted August 11, 2003 Yes. The bushings are inside of the control arm. It is usually unecessary to replace the arm itself. Unless it is fubared. I have a picture somewhere. I'll see if I can find it.
SPORTcoupe300 Posted August 11, 2003 Posted August 11, 2003 The bushings are the rubber parts at the connecting points of the control arms.
dwebb99 Posted September 4, 2003 Posted September 4, 2003 Meddle, I am considering replacing my bushings with the Daizen product. Have you done this yet? If so, I am sure we would all like to hear your comments on this product. All of our old Lexus's are in need of this replacement, and there doesn't seem to be many choices out there.
meddle Posted September 5, 2003 Author Posted September 5, 2003 Unfortunately I wont get around to doing this until sometime early next year. Im pretty sure that I will be going with Andrew Vlamos' OEM spec bushings. More expensive, but dont need the regreasing that the Daizens will eventually require, and will return the car back to its original form. Smooth ride, no squeeking. I think I will just rely on springs and shocks to upgrade the handling.
