lexus400 Posted September 2, 2006 Share Posted September 2, 2006 I have play in each rear wheel ('91 LS, 176k), the only thing I have done to the rear suspension is the bushing on #9, everything else is original. The play is coming from the "Rear control Arm"..... I can order the arm but the play is on the bushing pressed into the "Knuckle", #2. Is there a source/part # for that bushing ? Looks like the same procedure I did on the "Strut Rod/# 9 last year. thanks, Bob Quote Link to comment Share on other sites More sharing options...
maniek_LS Posted September 2, 2006 Share Posted September 2, 2006 I have play in each rear wheel ('91 LS, 176k), the only thing I have done to the rear suspension is the bushing on #9, everything is original. The play is coming from the "Rear control Arm"..... I can order the arm but the play is on the bushing pressed into the "Knuckle", #2. Is there a source/part # for that bushing ? Looks like the same procedure I did on the "Strut Rod/# 9 last year. thanks, Bob Bob, As I know there is only part #2 and here is bushing - you can look for after market (uorginal) bushing which fit. I hope you can find mechanic who know garage who will recuperate this part. Mariusz Quote Link to comment Share on other sites More sharing options...
