Jacob Posted August 31, 2006 Share Posted August 31, 2006 Hello everybody, I have a ’96 LS400 with the check engine light on. And I needed to do the emission test for my registration. So, I disconnected the battery terminal for a few minutes and then went to the emission testing. What I didn’t know is that they check the OBD…. Which they did and told me that the OBD system was not ready so they couldn’t do the test. Would it work if I went to Auto Zone and asked them to reset the fault codes? Thanks Quote Link to comment Share on other sites More sharing options...
bicol-ini Posted September 1, 2006 Share Posted September 1, 2006 yes you can reset it but if its a hard fault it will show up by the time you drive to your smog check station, if you have a scanner reset it just as you start to smog check it, it might work Quote Link to comment Share on other sites More sharing options...
Jacob Posted September 1, 2006 Author Share Posted September 1, 2006 Today, I had the codes erased at AutoZone then drove to the emission station (about 6 miles). The check-engine light was still off, and my car passed the inspection. Thank you bicol-ini Quote Link to comment Share on other sites More sharing options...
