lexwebb Posted August 10, 2003 Posted August 10, 2003 the check engine light came on and now the car runs rough. What is it? Just did the 90K service
dcfish Posted August 10, 2003 Posted August 10, 2003 :D :D :D bring the car back to where you had the 90,000 done and have them re scan the car , they should do this for free this time unless they find a seperate problem that they did not perform at 90,000
SKperformance Posted August 10, 2003 Posted August 10, 2003 when a CEL check engine light goes on it can be one of a fwe hundred things as it reads tons of sensors and values of each
JPI Posted August 10, 2003 Posted August 10, 2003 We should make this a rule for the future. If you have a check engine light please provide us the codes. This is most likely the hose from your intake air box came off. Check all your hose connect the air box. Yeah you need to bring the car back to whomever did the 90k service. JPI
SKperformance Posted August 10, 2003 Posted August 10, 2003 thanks i wanted to say that but since i have to kinda of stream line things i almost sounds like an arrogant !Removed! i looked through my scanner book and tehre is 50 pages of about 40 codes a page so there is no way i am going to post all 50 pages
