Rx 330-driving In 4th Gear
zmanfrnk
just wondering, why were you in forth gear?
After backing out of garage I shifted into 4th rather than "D". No reason, just screwed up.
You must have stopped for gas at least once. Did you screw up again after you gased up?
You did absolutely no damage. All you did was prevent the car from going into overdrive. The car will shift normally through all gears except 5th (overdrive). The only thing you did was burn more gas.
