Cherokee_Outlaw Posted July 18, 2006 Posted July 18, 2006 How do you get a dead spider out of the Headlight cover???
Rx330driver Posted July 18, 2006 Posted July 18, 2006 how did that happen... if it got in, that means there is a hole somewhere. tube with a vacuum cleaner?
steviej Posted July 18, 2006 Posted July 18, 2006 take the bulb out. get a good length of thick walled surgical tubing or rubber hose from the auto parts store. Use the hose from your vacuum. You will need something to downsize the opening of the hose to the width of the tubing. I tried a rubber glove and two wire ties. make a small hole in one finger and stick the tubing through there, secure it tightly with a wire tie. Put the vacuum's hose in the wrist opening of the glove and secure that with a larger wire tie. Leave little excess of the glove unsecured. This should create enough suction to get the spider carcass out of there. have fun. :P steviej
Cherokee_Outlaw Posted July 18, 2006 Author Posted July 18, 2006 take the bulb out. get a good length of thick walled surgical tubing or rubber hose from the auto parts store. Use the hose from your vacuum. You will need something to downsize the opening of the hose to the width of the tubing. I tried a rubber glove and two wire ties. make a small hole in one finger and stick the tubing through there, secure it tightly with a wire tie. Put the vacuum's hose in the wrist opening of the glove and secure that with a larger wire tie. Leave little excess of the glove unsecured. This should create enough suction to get the spider carcass out of there. have fun. :P steviej lol doesnt sound like fun!! I'm going to have Lexus pick up my car in few weeks to check out the Front Parking Assist... maybe I could talk them into being pest control for a day also... B)
sPY-007 Posted October 1, 2006 Posted October 1, 2006 From past experiences, once a spider gets in, baby spiders are most likely residing somewhere under the bonnet =) Enjoy!
