RedRocket Posted June 14, 2006 Share Posted June 14, 2006 My SC goes CLUNK when ever I step on the brakes going in reverse then goes CLUNK again when going forward. This only occurs the first time I hit the brakes after a direction change (forward/reverse). In prior forms there was a discussion about the pads moving in the calipers when going in a different direction. Does anyone know of clips/springs that stop tyhis annoying sound. My friends Camry uses small springs to push the pads one way and stops the sound. Thx Quote Link to comment Share on other sites More sharing options...
lexus082 Posted June 14, 2006 Share Posted June 14, 2006 My SC goes CLUNK when ever I step on the brakes going in reverse then goes CLUNK again when going forward. This only occurs the first time I hit the brakes after a direction change (forward/reverse). In prior forms there was a discussion about the pads moving in the calipers when going in a different direction. Does anyone know of clips/springs that stop tyhis annoying sound. My friends Camry uses small springs to push the pads one way and stops the sound. Thx It sounds like its a bad ball joint. I would recommend you check the ball joints to make sure there in good shape. When a ball joint goes bad you will get the same "clunk" as you described such as reversing and when you apply the brake...."clunk". The Sc should have springs mine does on both the front & rear. If not the part numbers for a SC400 are: (Front P/N 47743-24020 QTY. 4) & (Rear P/N 47743-50020 QTY. 4). Quote Link to comment Share on other sites More sharing options...
GrnHrnt Posted June 14, 2006 Share Posted June 14, 2006 My SC goes CLUNK when ever I step on the brakes going in reverse then goes CLUNK again when going forward. This only occurs the first time I hit the brakes after a direction change (forward/reverse). In prior forms there was a discussion about the pads moving in the calipers when going in a different direction. Does anyone know of clips/springs that stop tyhis annoying sound. My friends Camry uses small springs to push the pads one way and stops the sound. Thx Dry or worn propeller shaft universal joints can also make a "clunk" when switching direction. Quote Link to comment Share on other sites More sharing options...
jzz30 Posted June 14, 2006 Share Posted June 14, 2006 your pad could just be worn. look at the pads and see if they are worn Quote Link to comment Share on other sites More sharing options...
dcfish Posted June 14, 2006 Share Posted June 14, 2006 your pad could just be worn. look at the pads and see if they are worn If your sure it is the brakes you need new shim kits. The shim kits should be replaced every other pad change, I replace them every pad change ( just the way I am ). Quote Link to comment Share on other sites More sharing options...
jzz30 Posted June 14, 2006 Share Posted June 14, 2006 not necessarily, the pad backing metal may just be worn. i had the same problem an a GS400 and just changed pads and the noise was gone. Quote Link to comment Share on other sites More sharing options...
dcfish Posted June 15, 2006 Share Posted June 15, 2006 not necessarily, the pad backing metal may just be worn. i had the same problem an a GS400 and just changed pads and the noise was gone. Very well could be Quote Link to comment Share on other sites More sharing options...
RedRocket Posted June 16, 2006 Author Share Posted June 16, 2006 :D Thanks guys. I will check the ball joints, & springs. Replacing the front pads is the next item on my list along with installng SS hoses and flushing the system. Quote Link to comment Share on other sites More sharing options...
jzz30 Posted June 17, 2006 Share Posted June 17, 2006 wow! have fun with all that! Quote Link to comment Share on other sites More sharing options...
