godfather18 Posted May 30, 2006 Posted May 30, 2006 My Uncles ABS light has been on for about 1 year and his front brakes lock up sometimes, he replaced the fluids and replace his rotors and brake pads, but its still keep locking on him. When his brakes lock on him, he has to pull the negative off his battery off so they release. Does anyone have any clue what it could be. Thanks
steviej Posted May 30, 2006 Posted May 30, 2006 My Uncles ABS light has been on for about 1 year and his front brakes lock up sometimes, he replaced the fluids and replace his rotors and brake pads, but its still keep locking on him. When his brakes lock on him, he has to pull the negative off his battery off so thet release. Does anyone have any clue what it could be. Thanks he needs to get the ABS codes read to find out where in the system the trouble code originating and then start with that. steviej
SKperformance Posted May 30, 2006 Posted May 30, 2006 Probably needs new bearings and ball joints by now with that kind of abuse and neglect the repair bill will only keep mounting before the abs motor burns out too.
godfather18 Posted June 3, 2006 Author Posted June 3, 2006 went to autozone and found out that my abs or one of my sensors r bad.
steviej Posted June 3, 2006 Posted June 3, 2006 went to autozone and found out that my abs or one of my sensors r bad. that'll do it. The system was telling the caliper to constantly close. replace the sensor. steviej
Toysrme Posted June 7, 2006 Posted June 7, 2006 Wheel speed sensor. If you bump them around a tiny bit they won't pick-up right.
