boogieman Posted May 21, 2006 Share Posted May 21, 2006 How is this filter accessed on my '93LS? Where is it located? Quote Link to comment Share on other sites More sharing options...
obergc Posted May 22, 2006 Share Posted May 22, 2006 pry off the lower cover underneath the dash on the passengerside. There are two wingnuts on the bottom the evaporator that holds on a plate located near the blower motor. Remove the wingnuts and plate and the filters will drop out the bottom. There are two and they bend in the middle during removal so you can get them in and out. When you reinstall the new ones, you install the first, slide it towards the firewall and then the second. Quote Link to comment Share on other sites More sharing options...
boogieman Posted May 22, 2006 Author Share Posted May 22, 2006 Pry the cover off? There aren't any fasteners? Whats the best tool to use? A screwdriver, flat bar, small flat nail bar, pry bar, or what would you suggest? I don't want to damage the cover or the dash pad, so I'm slightly reluctant. Quote Link to comment Share on other sites More sharing options...
boogieman Posted May 22, 2006 Author Share Posted May 22, 2006 Pried that sucker right off. Filter dirty, cleaned it out, cleaned the rubber seal gasket, right back together. Thanks for the location info. Quote Link to comment Share on other sites More sharing options...
obergc Posted May 22, 2006 Share Posted May 22, 2006 Glad to see you got the job finished ok. Although a little late with the info, I always use an old, flat blade table knife to pry the cover off. It's worked well for me and never left a mark on the covers. Quote Link to comment Share on other sites More sharing options...
