webdev Posted April 27, 2006 Posted April 27, 2006 Good solution for radar detector for IS350? I know which radar detector to get but the bummer is it is a corded radar detector and the cord would run right in the middle of the gps screen. I am contemplating the solo 2 cordless but I am not that excited about going thru a ton of batteries. Anyone using a radar detector for the IS350 with nav? If so what is your setup and where are the power cables runing? Thanks...
Cherokee_Outlaw Posted April 27, 2006 Posted April 27, 2006 Good solution for radar detector for IS350? I know which radar detector to get but the bummer is it is a corded radar detector and the cord would run right in the middle of the gps screen. I am contemplating the solo 2 cordless but I am not that excited about going thru a ton of batteries. Anyone using a radar detector for the IS350 with nav? If so what is your setup and where are the power cables runing? Thanks... Never priced one.. since I'm a believer that a detector only gives you false security so I dont have one... BUT.. I guy that came up talking to me about my car.. said I should get the K40 w/ Bluetooth... I guess it mounts on your front/rear Lic Tag.... and its all Bluetooth... thats all I know... He had a Q45 and loved the K40..
bartkat Posted April 27, 2006 Posted April 27, 2006 I velcroed mine to the dash just to the right of the center speaker and the cord runs down to the right of the center stack and then across a little to the cig lighter socket. It stays completely out of the way and seems to work fine.
adam81 Posted June 1, 2006 Posted June 1, 2006 Good solution for radar detector for IS350? I know which radar detector to get but the bummer is it is a corded radar detector and the cord would run right in the middle of the gps screen. I am contemplating the solo 2 cordless but I am not that excited about going thru a ton of batteries. Anyone using a radar detector for the IS350 with nav? If so what is your setup and where are the power cables runing? Thanks... I have the SOLO 2 and it got to be a pain replacing batteries so I ended up just getting the power cord for it. I had to replace the batteries about once every 3-4 weeks. I have also heard of some people just getting the radar detector hard wired to the battery so it turns on and off when the car is turned on or off. I havn't heard of any complaints about it ... yet.
toothpickdude Posted June 15, 2006 Posted June 15, 2006 bringing back an old thread, you can hard wire the detector, usually takes about 5mins to do. I have a Valentine 1 in my Dodge srt-4(im a troll my sis has an is300 :P) works great, i run the cord from the fuse box up thru the driverside a-pillar, up across the top (tucked into the headliner) then into the unit which is attatched to the windshield next to my rear view mirror
