Tiny Amount Of Oil Leaking From Behind The Transmission Pan
I was doing my usual spring oil change when I found that there is a tiny leak///1 drop per week of oil coming from the gasket (red) behind the transmission oil change pan. Is that the differential? Torque converter? Is this an easy fix to redo the gasket? :cries:
its not hard to change the gasket i had a 94 es300 and had changed the transmission pan gasket make sure to get the all rubber gasket not the cork type gasket its not good cause i have put both the cork one didnt last long ull get them at a local auto store i got mine from Orielly autozone had the cork one not good it comes with the filter too replace it 10 metric size bolts,about 16 or 17 .
