Gs300 Sub Replacement
to do that you will have to take the back seat off and the side pannels in the rear to, it takes about 25 min to do it and 25 min to put it back on. but it is not worth just changing out the sub, the stock amp does not push it. i tried it, then just when with a aftermarket amp and 2 12" subs. good luck
  • 1 year later...
so the only way to replace that 10" sub is to remove the back seat huh!
wow.....looks like I got a project on my hands!
I purchased a 10" Solo Baric
Impedance: 4 ohm
Power: 450 watts
Frequency Response: 24-100 Hz
Mounting Depth: 4 7/8"
Mounting Hole: 9 3/8"
Recommended Enclosure: .66 cu. ft
and this amp for it
2 x 300 Watts RMS at 4 Ohms
2 x 600 Watts Max at 4 Ohms
1 x 1200 Watts Max at 4 Ohms Bridged
2 x 500 Watts at 2 Ohms
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohms Stereo Stable
Tri-Mode Capable
Gold RCA Inputs
Line Outs For Left & Right Channels.
Power & Protection LED Indicators
Advanced Protection Circuitry
Soft Turn On/Off
Remote Control Bass Booster
Frequency Response: 15 Hz - 35 kHz
S/N ratio: 90dB
Dimensions: 11.5"W x 2.3"H x 15"L
So hopefully I will get some good sound out of it.....will see
So tell me whats the process without breaking anything to remove the sub?
step by step if you can guide me.
I am ready got all the gear in today.
Thanks
It's 4 bolts, big deal! The only bad thing is that you have to remove the rear deck, BE CAREFUL!!!! 12 yr old plastic doesn't like to be disturbed!!!! :lol:
could you explain step by step of replacing the amp and the sub?
Pull the bottom part of your set up and outward on both sides,
remove the headrests, under the velcro flap theres a 10mm nut remove it
from both sides, then remove the seat belt bolts on the bottom where the bottom seat piece was removed, then remove the two 10mm bolts on the bottom holding the back panel seat in place, now remove the little screws from the shoulder straps seatbelts, ontop of the backseat rest. now remove the three black plastic push rivets with a flat head scewdriver (on the back panel). now pull the molding outward where the end of the window is it looks like this ---> ( pull that molding out just enough to remove the right side back piece against the left and right side,
those two pieces are holding the back panel in, so remove those pull a little hard,
then the back panel pulls out real easy. then remove sub and replace.
then follow the steps backwards to put back.
  • 5 years later...
  • 2 years later...
I replaced mine with a lightning audio ten inch sub and the only problem was that the screw holes did'nt line up so I had to drill more holes but other than that it was easy.
I'm really new to all these DIY for car electronics. So could you please give me lil more details as to what else did you replace with Lightning Audio sub? I mean, were you able to just swap the Lighting Audio sub with OEM sub and it worked okay or you also replaced other parts as well such as amp etc.? Thanks in advance.
  • 6 years later...
