Ferinheit To Celcius
Swavik
- I own a 2000 RX-300 - The U.S model
- I live in Canada
- Does anyone know how to change ferinheit to celcius on the LCD display?
- Also, is it possible to change the odometer to display kilometers vs. miles?
- Thanks for your help.
  • 9 months later...
- I live in Canada
Hi.
I'm from Greenland.
I'm just curious if you have succeeded chancing your LCD display into celcius? Please let me know if you have, because I'm having the same thought for my LX 470.
Thanks in advance :)
I am in the same situation with a 2004 RX330. There is no option I know of to change the information display. I have searched many forums for an answer to no avail. I called Lexus and they do not have a solution either. I think this is ridiculous, I had a 1998 Oldsmobile that with the push of a button I could switch back and forth from metric to imperial/English as much as I wanted. What is with Lexus?? There is a dash speed odometer replacement for the Lexus but this only gets you the numbers larger in KPH vs MPH and that’s it.
  • 4 months later...
  • 1 year later...
I have the same problem! Does anybody have a solution?
Thanks
I know how to change
miles to km/h
km/h to miles
F to C
C to F
RX300
RX330
RX350
PM or Details
Gregor001 B)
Can you post how to do this, as this seems to be a common question.
Cheers
I remember an old post about a 330 owner accidently switching his NAV langauge to French. And as expected NAV voice changed to French and metric. He then switched backed to English but measurments remained in metric. Anyone care to try this?
I have a 2001 without NAV and no need for metric but some odd reason remembered this old post.
  • 3 weeks later...
  • 2 months later...
This was Gregors response to my PM:
"so you need someone who will help you solder and read eprom, than I will help you and you will get KM/H and C"
Thanks Gregor! NOT
I have a reader, but don't know which values should i fix?
