jpcass0 Posted April 10, 2006 Share Posted April 10, 2006 My passenger side floorboard is pretty wet after recent rains. Has anyone had, or heard of, water leaks into the passenger compartment from the dash, door, or elsewhere? My windows and sunroof have been closed and the seals appear to be fine. I think the water must be coming in from the door or below the dash. Anyone have any ideas on how to locate and repair the leak? Quote Link to comment Share on other sites More sharing options...
Rookie Posted April 10, 2006 Share Posted April 10, 2006 My passenger side floorboard is pretty wet after recent rains. Has anyone had, or heard of, water leaks into the passenger compartment from the dash, door, or elsewhere? My windows and sunroof have been closed and the seals appear to be fine. I think the water must be coming in from the door or below the dash. Anyone have any ideas on how to locate and repair the leak? A couple of the common reasons for this are clogged drain slits in the bottom of the rocker panels, or clogged sunroof drain tubes (four of them, one in each corner of the sunroof). I'd check those areas first. Rookie. Quote Link to comment Share on other sites More sharing options...
dougjohn2 Posted April 13, 2006 Share Posted April 13, 2006 My passenger side floorboard is pretty wet after recent rains. Has anyone had, or heard of, water leaks into the passenger compartment from the dash, door, or elsewhere? My windows and sunroof have been closed and the seals appear to be fine. I think the water must be coming in from the door or below the dash. Anyone have any ideas on how to locate and repair the leak? Check the bottom corners of the windsheild glass. Mine's leaking from there --0 th edrips are very obvious when it's raining. if you find thi sis the problems, you'd need to seal it somehow or replace the windsheild gasket. Quote Link to comment Share on other sites More sharing options...
jpcass0 Posted April 19, 2006 Author Share Posted April 19, 2006 Thanks a lot for your suggestions! It is raining today so I will check it out. Quote Link to comment Share on other sites More sharing options...
lexus411 Posted April 19, 2006 Share Posted April 19, 2006 I had/have the same problem. I didnt notice mine until after I had the windshield replaced. A few days later it went crazy. The remote starter wouldnt shut off. It ended up frying my starter. Turns out the water leak shorted my computer and everything else. I had it re-sealed again. And I noticed a day ago it was back. Quote Link to comment Share on other sites More sharing options...
