Wicked_Lex Posted April 6, 2006 Share Posted April 6, 2006 There are probably some threads about this, but most of what I have seen regarding suspension is about coil-overs and L-tuned S/S for guys who want lowering. I need new shocks and I want to keep the stock spring but reduce the roll when cornering. What would be a better shock than OEM Lexus and what is the approximate cost for 4 shocks? Thanks guys Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted April 7, 2006 Share Posted April 7, 2006 The KYB GR-2 seem to work well for me. They are a little stiffer than stock, but not much. Fronts are $86.00/ea and the rears are $96.00/ea at Tirerack. I feel that the roll was reduced dramatically when I added the TRD anti-roll bars both front and rear. The TRD Sportivo anti-roll bars (sway bars) set me back about $300.00. They were well worth it in my opinion. Of course, there are many other types at various prices. I found them on Ebay. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted April 7, 2006 Share Posted April 7, 2006 If you want less roll but not height then you just need new roll bars. Quote Link to comment Share on other sites More sharing options...
Neo Posted April 8, 2006 Share Posted April 8, 2006 Although shocks and springs work together, body roll is more a function of the springs than the shocks. I agree with the others as far as sway bars. In your case, if you like the OEM ride quality, replace the shocks with OEMs and invest in a set of aftermarket sway bars. The Daizens are probably your best bet. Quote Link to comment Share on other sites More sharing options...
viclykewhoa Posted April 8, 2006 Share Posted April 8, 2006 Although shocks and springs work together, body roll is more a function of the springs than the shocks. I agree with the others as far as sway bars. In your case, if you like the OEM ride quality, replace the shocks with OEMs and invest in a set of aftermarket sway bars. The Daizens are probably your best bet. Hey Neo, Where would I be able to pick up a set of Daizens for my 1999 GS300. I've been looking around online and have only found the TRD sway bars. If you could link me to a site that would be great. Thanks. Quote Link to comment Share on other sites More sharing options...
Wicked_Lex Posted April 9, 2006 Author Share Posted April 9, 2006 Thanks guys, I'm going with a Bilstein Sport shock and if I still have too much roll I'll look into sway bars. Quote Link to comment Share on other sites More sharing options...
Neo Posted April 10, 2006 Share Posted April 10, 2006 Although shocks and springs work together, body roll is more a function of the springs than the shocks. I agree with the others as far as sway bars. In your case, if you like the OEM ride quality, replace the shocks with OEMs and invest in a set of aftermarket sway bars. The Daizens are probably your best bet. Hey Neo, Where would I be able to pick up a set of Daizens for my 1999 GS300. I've been looking around online and have only found the TRD sway bars. If you could link me to a site that would be great. Thanks. Try TMEngineering. Todd is great because he knows the product inside out, partly because he did a lot of the R&D for Daizen. The website is http://www.tmengineering.net Quote Link to comment Share on other sites More sharing options...
