No i don't get any beep.
That also explains why it may not sound as hard as mine as it is not a perfect box.
My original box is ported but is not made like any normal one i have seen before.
I don't think JL even sells the H.O. box by itself to add a driver to later on.
i think the beep is suppose to be there because when i put the stock sub back it covers it up and it stops the sound from getting in the car
the beeping sound comes from your power and RCA lines being close together to eliminate that noise you must run one line down one side of the car and the other on the opposite side of the car
That is a good possibility but his rca's run from the trunk lid down not along the side of the car.
It should be no more than 4 feet of wire.
I would also try a different rca wire.
well that woudlnt explain it because i pulled out everything and i still got the nosie its some type of part in the car ill try to get a picture if i can but its in the hole where the stock sub is because i stuck the stock sub back in and it was gone so im thinking the stock sub was kinda of like a sound deadening device to keep that noise out
